Getting “Hmmmm… your Internet access is blocked.” error message on edgeSolved
1 year ago Feb 04, 2025
Hey,
After resetting my Windows 11 Pro laptop, Microsoft edge started throwing this error:
I tried the basics like rebooting, resetting edge settings, and even disabling the firewall and antivirus temporarily. Still nothing.
Has anyone faced this before or know what else I could try?
1 year ago Feb 10, 2025
I’ve seen this happen after a reset where certain network settings get messed up. In your case, it might be the proxy settings causing the trouble.
Try this:
    1. Press Windows + I to open settings
    2. Navigate to Network & internet > proxy
    3. Turn off Automatically detect settings
    4. Restart your PC and try opening edge again
Sometimes windows re-enables auto-detection after a reset, which can lead to weird issues like this.
1 year ago Feb 14, 2025
You can also try resetting the TCP/IP stack in case something deeper config got altered
Open Command prompt as admin and run this:
netsh int ip reset
That’ll reset your internet protocol settings to default. Restart the pc once it’s done, and check if the error goes away.
1 year ago Feb 18, 2025
Turning off “Automatically detect settings” in the proxy section actually did the trick!
I also ran the netsh int ip reset command just to be safe. Edge is working perfectly now.
Thanks a ton, both of you!
