Do I need to upgrade my plan to use App Bundles?Solved
5 hours ago Mar 16, 2026
Hi everyone, I’m currently on the Ultimate plan and I was wondering if I need to update my subscription in order to use App Bundles. I’m trying to add an application to my inventory using its Bundle ID, but I wasn’t sure if this requires a higher plan or some extra configuration. Could someone clarify?
4 hours ago Mar 16, 2026
 I thought App Bundles were only available if you upgraded, but turns out that isn’t the case i guess.
2 hours ago Mar 16, 2026
Thanks for raising this question.
Since you are already on the Ultimate planyou have full access to App Bundles. There is no need to upgrade your subscription.
If your goal is to add an application using its unique Bundle IDhere’s the navigation path:
  • Go to the Apps tab.
  • Select Local Apps from the left sidebar.
  • Click the Add Apps button in the top right.
  • Choose With Bundle ID from the dropdown menu.
If instead you were looking to group several apps together for easier deployment, that’s handled through App Groups:
  • Navigate to Apps > App Groups.
  • Click +Create App Group to bundle your existing inventory into a single package.
For more details, you can check the guide: How to configure App groups
