Disabling Battery OptimizationSolved
9 months ago Jun 19, 2025
Hey Everyone,
So, during enrollment where you configuring permissions How do you disable battery optimization for hexnode? The ability to change it for hexnode is greyed out.
9 months ago Jun 20, 2025
Hi @alvinli,
Thank you for reaching out.
The capability to disable battery optimization varies by device manufacturer and cannot be altered from Hexnode’s side. However, if you provide the device model and OS version, we can verify from our end as well.
Cheers,
Eden Pierce
9 months ago Jun 23, 2025
@edenpierce Thanks for your response. These are samsung galaxy tablets.
SM-P613 and SM-X710. The OS version are all different each so would be 13, 14, and 15.
Thanks for the update, @alvinli. This behavior is expected on these models, and as mentioned earlier, it may vary from model to model. Let us know if you have any other questions!
Cheers,
Eden Pierce
