Device compliance errorSolved
4 weeks ago Jan 10, 2026
Hi everyone,
I have a device that is showing the following message under Compliance Status:
List of Violation(s):
  • Compliance Criteria: Device Encryption
  • Value: true
Does anyone know what could be causing this?
Replies (7)
Which device is this?
4 weeks ago Jan 11, 2026
Oh, I forgot, it’s an iPhone 11.
This usually happens when encryption isn’t enabled on the device.
Hi,
As @pauel said, in this case, the iOS device is marked as non-compliant since the device encryption is not enabled. Device encryption is a critical security requirement as it ensures that all data stored on the device is protected and cannot be accessed without proper authorization.
For iOS and iPadOS devices, encryption works slightly differently compared to other platforms:
  • iOS devices automatically enable encryption once a device passcode is configured.
  • If the device does not have a passcode, encryption remains disabled.
  • As a result, the device will fail compliance checks related to encryption.
To maintain compliance, every user must set a secure passcode on their iPhone.
4 weeks ago Jan 12, 2026
Should it be a password or a PIN code? Is that for the Apple ID? Because on the iPhone, there is only a PIN code or the Apple ID password.
Hi,
To avoid confusion, let me explain this in detail.
The password mentioned here does not refer to the Apple ID password. Instead, it refers to the device passcode, which is the code used to unlock the iPhone itself. This can be configured as:
  • A numeric PIN (4-digit or 6-digit), or
  • An alphanumeric passcode (which Apple also refers to as a “password”)
Once any supported device passcode is set, iOS automatically enables full device encryption, and the device should pass the encryption compliance check.
Thanks, appreciate the help.
