Custom SSL configurationSolved
2 months ago Feb 01, 2026
How do I create a custom SSL VPN connection in the policy for deploying the Cato Client on macOS? I was referring to this deployment document, but it appears to be for a different MDM.
Hi @douglas,
You can set up a custom SSL VPN connection by deploying a custom configuration profile directly to your macOS devices. The necessary profile configuration is available in the Cato Client documentation: Deploying and Upgrading macOS Clients with an MDM. To deploy this, you can use Hexnode’s Deploy Custom Configuration feature.
2 months ago Feb 02, 2026
Oh alright, I was a bit thrown off when I couldn’t find the attachment. I was looking at creating a VPN profile in the MDM.
2 months ago Feb 03, 2026
Thanks for the update.
Kindly note that the VPN profile is already included within the provided configuration file. You do not need to create a separate VPN profile in Hexnode.
You will only need to configure the required system extensions in Hexnode for the setup to work correctly.
