Clear app data on Apple TVSolved
8 months ago Jul 21, 2025
Hey all, we’re using Hexnode to manage our Apple TVs, and one of our requirements is to clear app data for specific apps from time to time. Is there a way to do this directly through Hexnode, perhaps via a custom configuration profile or any other supported method?
Replies (7)
I’m not entirely sure, but you might want to try using the Uninstall Application action in Hexnode. I believe that could help with clearing app data.
Hi, as @aitana suggested, using the Uninstall Application remote action in Hexnode is a practical way to clear app data on Apple TVs.
8 months ago Jul 22, 2025
That really helped!
8 months ago Jul 23, 2025
Hi, is this the same procedure for Android devices as well? We have a few devices that need app data cleared.
No, for Android devices, there is an action called “Clear App Data” in Hexnode. You can use that to wipe the app’s data without uninstalling it.
Just a heads up, the Clear App Data action on Android devices works specifically on Samsung Knox devices and Android Enterprise devices running Android 9.0 and above.
8 months ago Jul 24, 2025
Thank you, I’ll try that out!
