Can’t manually install apps…. Play Store icon is goneSolved
2 months ago Jan 21, 2026
We have some Android tablets enrolled as Device Owner and locked in Kiosk mode.
I need to manually install a specific app using a personal Gmail account for some field testing, but I cannot find the Google Play Store app anywhere on the device. Even if I exit Kiosk mode, the icon isn’t in the app drawer.
Is Hexnode hiding it? How do I get it back so I can sign in?
If the device is in Device Owner mode, the Play Store behaves differently (it’s usually the “Managed Google Play” version).
But if the icon is completely gone, check your Android > Restrictions policy. There is a specific toggle for the “Google Play Store.” If that’s disabled/restricted, the OS hides the app icon entirely to prevent users from installing unapproved apps.
2 months ago Jan 22, 2026
Yeah, @aurora is right. You likely have it blocked the policy.
You’ll need to:
  1. Go to the Policy applied to that device.
  2. Enable the Play Store in the Restrictions.
  3. Sync the device.
Once the icon appears, you’ll probably have to exit Kiosk mode temporarily to open it and add the personal Gmail account, since the “Add Account” screens are usually blocked in Kiosk.
