Can you find the phone number from the console?Solved
2 months ago Feb 18, 2026
Hi, is it possible to find the phone number associated with your Android devices from the Hexnode console?
@sloane , Yeah, it is possible, you can find that under the device info.
@diane_ , where do I find the device info and where in device info do I find the number?
@sloane , just go to the Manage tab and select your device. A device summary page should open. Under this summary page, there will be a sub-tab called “Device Info”– just click on it and here under Network settings, the phone number is the first thing you would see. Just scroll down if you have a second SIM, to see the second number.
Oh, I got it, thanks @diane_
