App store layout issue in AndroidSolved
4 months ago Dec 01, 2025
Hey everyone, we had set up an app collective in the Managed Google Play Store, but only a handful of apps are showing up. We expected all apps to be listed. Has anyone faced this issue? How can it be resolved?
4 months ago Nov 30, 2025
Yes, I’ve seen something similar. Sometimes only approved apps appear, while others don’t sync properly. Is that the case?
In our case, it was a permissions thing. The apps were added, but they weren’t visible to all user groups. Could that be happening here?
Another possibility is caching. I’ve noticed that changes in Managed Play take a while to propagate. Maybe give it some time?
If you want your Managed Google Play apps to actually show up in Hexnode, the flow is pretty simple: get your Android Enterprise setup done, hop into the Hexnode console, add the apps you need, and push them out to devices. The real trick though is the store layoutthat’s what decides what people actually see in their Play Store. So, set up pages, group apps into collections, save it, and clear the Play Store cache on devices. Without that layout, even if you’ve added apps, they might stay hidden.
 Okay will look into it and update the same.
