I associated a policy for app configurations on my iOS devices, but the app configurations haven’t changed on the device end.
App configurations not applying on iOS devicesSolved
3 weeks ago
Mar 16, 2026
Did you encounter any errors while uploading the XML file? Sometimes upload errors can block the configurations from applying. For example, Apple services may throw errors if the XML has invalid formatting or unsupported keys.
3 weeks ago
Mar 16, 2026
No, I didn’t get any errors during the upload.
3 weeks ago
Mar 16, 2026
Hello @margaret ,
If no errors occurred during the XML upload, the issue is likely due to invalid configurations within the XML file itself. Common causes include mismatched bundle identifiers, unsupported configuration keys, or incorrect XML structure. Try verifying the XML configurations and uploading a properly formatted file. This usually resolves the issue and ensures the app configurations apply correctly on the device end.
