App Blocklisting in place, but browser access is still open. What’s the next step?Solved
4 days ago Apr 09, 2026
We’ve been trying to control unauthorized apps in our environment. Blocklisting helped a bit, but people are still using personal cloud storage through browsers. How are you all dealing with that?
Yeah, we hit the same issue. Blocking the app only goes so far—people just open it in a browser. We started using URL filtering to block those sites, and it actually cut down a lot of that usage.
Just need to be careful though, we blocked a bit too much at first and it started affecting legit work.
Same here, managing the blocklist became a bit of a headache after a while. Every other day someone needed an exception 😅
We ended up keeping the important stuff open and blocking the rest. Also, on iOS supervised devices, turning off private browsing and not letting users clear history helped a lot with visibility.
Ah okay, makes sense. What about different browsers though? We’re seeing different behaviour across Chrome, Edge, Safari… especially on Windows.
Yeah, that’s normal. On Windows it really depends on the browser. We just picked a few approved ones and enforced policies there, otherwise people just switch browsers and bypass it.
For us, things only really worked properly when we used bothblocklisting apps + web filtering. One without the other just leaves gaps.
