Accessing Documents / SharepointSolved
1 month ago Oct 16, 2026
I’m trying to create a document / resource hub that staff members can access via their androind kiosk mode but also notify them when they need to complete surveys etc. As a business we use Sharepoint and I had considered using the sharepoint app but with over 250 staff members / Devices, it’s going to add a significant monthly cost so i’m looking into alternatives if anyone has any suggestions or knows if Hexnode has something built in that could do the job?.
4 weeks ago Oct 22, 2026
Hi @meddyg_care,
You can set up a resource hub on your Android kiosk devices using Hexnode’s built-in kiosk features.
For your document hub: You can add SharePoint pages, survey links or other web resources as Web Apps in Android kiosk mode, allowing staff to access them through a controlled kiosk setup. For static resources, such as PDF manuals and guidelines, Hexnode also supports adding document shortcuts directly to the kiosk home screen.
For notifications: Hexnode’s Broadcast Message feature lets administrators send messages to selected devices or groups. To make these messages accessible in Android kiosk mode, enable View messages sent by admin under Android Kiosk Lockdown > Peripheral Settings > Messenger in your kiosk policy. While broadcast messages help remind staff to take a survey, please note that they won’t track completions.
Let us know if you need help setting this up!
