Hello @haniel ,
The Add bulk devices with CSV option can be unavailable for two common reasons:
- Dynamic Device Group: If the group is dynamic, manual and CSV-based additions are disabled because membership is controlled by rules.
- Plan availability: CSV-based bulk addition to device groups is available only on the Ultimate plan and higher. If the Hexnode UEM portal is on the lower plan, the option appears grayed out even for static device groups.
If you want to assign already enrolled devices to a static group without using CSV, you can use bulk selection:
- Go to Manage > Endpoints.
- Select the checkboxes next to the devices you want to group.
- Click Actions > Add devices to group.
- Choose the target device group.
This lets you add multiple enrolled devices to a group at once without opening each device individually.
For a more automated approach, use Dynamic Device Groups. You can create rules based on attributes such as OS type, device model, ownership, enrolled date, device name, or domain. Hexnode UEM will automatically add existing and newly enrolled devices that match those rules.
