Agent Mode is literally everywhere now… are they even the same thing?Solved
11 months ago Jan 01, 2026
Hey folks,
I was googling around for some Windows admin stuff and stumbled into a massive rabbit hole. Suddenly everything has an Agent Mode.
Microsoft is pushing Agent Mode for Excel, PowerPoint, and Word. Visual Studio just dropped a Copilot Agent Mode. Warp terminal is bragging about their AI agent replacing workflows, and my Reddit feed is full of people trying to trigger Agent mode in ChatGPT.
But here’s my confusion: an agent in Excel sounds like a glorified macro tool, while in Warp it’s literally executing shell scripts. Are these even the same tech? It feels like they all have completely different definitions. Did big tech just agree to slap the word Agent on every AI feature this year?
11 months ago Jan 02, 2026
Having played around with the VS Copilot and Warp features lately, I can tell you they do all share the same underlying DNA.
It’s all AI, but the definition of Agent here marks a major shift from Assistant to Action-taker. In the past, an AI just spit out text and you had to copy-paste it. Now, an Agent is an LLM that is given permission to use tools and interact with the specific environment it lives in. The definitions look different purely because the environments (a spreadsheet vs. a codebase vs. an OS) are different!
10 months ago Jan 03, 2026
Okay. So the environment is what dictates what the agent does. In Visual Studio, its environment is my project files, so it can read my code, write new files, and apply fixes.
But what about the Microsoft 365 stuff? How is an Agent in Excel different from the regular Copilot sidebar we’ve already had for a year? Is it just doing what the old Clippy did, but with ChatGPT brains?
10 months ago Jan 04, 2026
Well, think of regular Copilot as a passenger holding the map, it suggests turn left here (like autocomplete, or summarizing a document for you). You still have to do the work. Agent Mode is when you let the AI take the steering wheel.
If you ask regular AI to clean up an Excel sheet, it gives you a formula to copy. If you use Agent Mode, it takes your prompt, writes a Python or VBA script in the background, executes it, checks if it threw an error, fixes its own bug, and hands you the finished pivot table.
That’s exactly what the ChatGPT and Warp agents are doing too. In Warp, it doesn’t just tell you which command to run; it runs the command, reads the console error if it fails, and tries a new command on its own to fix it. That autonomous loop; plan, execute, observe, adjust, is what makes it an Agent, and it all leads back to the same AI reasoning engines.
