When should you use an emergency “wipe everything” response?Solved
1 day ago Apr 09, 2026
In a serious security situation (like a stolen device or compromised account), when do you actually go for a full wipe instead of just locking the device or removing access?
I’ve heard of setups where companies trigger an immediate “lockdown + wipe” kind of response, but that sounds pretty extreme. In what scenarios is that actually justified?
@eliiza, yeah, that kind of response is extreme, and it’s meant to be. Think of it as something you only use when you’re sure the risk is real and immediate, not just “something feels off.”
 Typical cases where a full lockdown + wipe makes sense is when:
  • A company device is stolen while unlocked or has sensitive data on it.
  • A high-privilege employee is being terminated and there’s concern they might misuse access.
  • You have clear evidence of compromise (like MFA bypass or admin access taken over).
 In those situations, just locking the device or resetting passwords may not be enough. There’s still a window where data can be copied or misused. That’s where a “hard response” comes in:
  • Sign the user out everywhere
  • Cut off network access
  • Lock the device
  • Remove company data
  • And if needed, wipe the device completely
 The idea is simpleAct fast, assume worst case, and reduce exposure immediately.
 It’s not something you use often, but when you do, speed matters more than convenience.
