Scaling 802.1X globally without losing my mind?Solved
2 months ago Feb 03, 2026
Hey everyone, I’m hoping someone can point me in the right direction. We’re rapidly expanding and currently setting up enterprise Wi-Fi (802.1X) across five new global branch offices. Manually deploying these networks to hundreds of devices is turning into a massive administrative bottleneck, not to mention the security nightmare of people sharing static Wi-Fi passwords. Is there an efficient way to automate this through Hexnode without having to create dozens of distinct regional profiles for our different locations?
2 months ago Feb 04, 2026
Managing shared credentials across global offices is a fast track to password fatigue and network vulnerabilities. Maybe you can shift to certificate-based authentication (like EAP-TLS) to automate the process. The biggest trick I learned from deploying this myself: always bundle your Wi-Fi configuration and your Identity/Root CA certificates inside the exact same Hexnode policy. If you segment them, the Wi-Fi payload can’t bind the certificate properly. To solve your scaling issue, just use the %username% wildcard in the Identity/Username field of the Wi-Fi payload. Hexnode will dynamically pull each user’s AD or local username, meaning a single global payload will scale perfectly for everyone without needing a custom profile for every site.
Ah, that’s a time saver. I do have a couple of follow-up hurdles, though. First, in our densest offices, our router performance is tanking due to massive RF overhead from devices aggressively probing the network. Second, when we briefly tested certificate deployments, some of our Android endpoints flat-out rejected the silent installation. Did you run into either of these snags?
2 months ago Feb 06, 2026
Oh, I think I have a couple of suggestions. For the RF overhead, check if you have the Hidden Network option enabled in your Wi-Fi configuration. If your devices are constantly probing for hidden SSIDs, it creates intense network congestion in high-density environments; make sure that’s set to Disabled unless functionally mandatory. As for the Android devices rejecting the certificates, it’s almost certainly because those endpoints don’t have a secure lock screen. Both Android and iOS will natively block enterprise certificate installations if there’s no passcode enforced. You just need to deploy a strict Password Policy before your Wi-Fi payload hits the device. I think this might be helpful. Please let me know when you’re finished.
