Retrieving disenrolled devicesSolved
1 month ago Jan 10, 2026
Hi guys, is it possible to retrieve an Android device (Samsung) from Hexnode after it has been disenrolled and deleted? The device is no longer showing in the portal.
Replies (6)
4 weeks ago Jan 11, 2026
I don’t think so. Once a device is disenrolled, it’s basically removed from the portal, so communication with it is lost.
4 weeks ago Jan 12, 2026
Got it. The issue is that we forgot to remove the restrictions on device reset before disenrolling and deleting the device. Now the device is locked and we are unable to proceed. Is there any way Hexnode can help unlock it?
Hi @ryker,
Since the device was forcibly disenrolled to free up the license, Hexnode completely loses communication with the device, so we are unable to make any changes or remove restrictions afterward.
Unfortunately, this means Hexnode cannot assist further with unlocking the device.
4 weeks ago Jan 13, 2026
Is there any alternative solution we can try?
Hi,
At this point, we recommend contacting the device manufacturer directly, in this case, Samsung. They may be able to help you recover or unlock the device, depending on their policies and proof of ownership.
4 weeks ago Jan 14, 2026
Thanks, really appreciate your help.
