Patch source validationSolved
11 months ago Apr 27, 2025
We’ve been revisiting our patch management process and one term that keeps coming up is Patch source validation. I understand it’s about using trusted sources for updates, but I’m wondering what exactly counts as “validation” in this case. And how does this help reduce the risk of supply chain attacks?
11 months ago May 01, 2025
Hi @bram
Good question. Patch source validation is essentially making sure any software patch or update comes from a trusted and verifiable source, whether that’s an OS vendor, a signed app repository, or a known third-party vendor.
The relevance to supply chain security is that attackers increasingly target the update paths themselves. If a patch comes from an untrusted or compromised source, it can serve as a delivery mechanism for malicious code. Validating patch sources helps ensure the software hasn’t been tampered with before it reaches your systems.
11 months ago May 03, 2025
Adding to what @akemi said, we follow a few steps to keep things clean on our end:
  • All updates go through official vendor channels only.
  • For third-party apps, we either verify the publisher’s digital signature or compare the file’s checksum to a trusted source to ensure it hasn’t been altered.
  • Nothing gets pushed to production until it’s passed internal testing.
It sounds like extra work, but it’s worth it. Especially with how sophisticated some supply chain attacks are getting. If your update source isn’t locked down, you’re taking a risk every time you install something.
10 months ago May 10, 2025
Appreciate the insights, both of you.
10 months ago May 16, 2025
Jumping in, we’ve been using Hexnode’s patches and updates feature to manage macos updates lately.
It’s been helpful for tracking available updates and scheduling them remotely, but just to confirm, are these updates always pulled directly from Apple? We’ve been cautious about unintentionally installing anything from an untrusted source.
10 months ago May 20, 2025
Thanks for bringing that up, @ryker
Yes, macOS updates triggered through Hexnode are downloaded directly from Apple’s servers. Hexnode just initiates the update, it doesn’t host or modify the files in any way.
So, in this case, patch source validation is inherently taken care of.
Cheers,
Eden Pierce
