New Wi-Fi SSID policy not auto-connecting on AndroidSolved
2 months ago Feb 18, 2026
Hey all,
We pushed out a new Wi-Fi SSID through a policy, and it shows as applied, but the devices are still hanging on to the Wi-Fi they were already connected to.
I was expecting them to jump to the new network once the policy hit. Is this just how Android handles Wi-Fi, or am I missing something here?
Seems like we ran into something similar earlier. Leme check. Just to confirm, which enrollment are you using?
2 months ago Feb 19, 2026
We are using Android device admin enrollmentAny clarity on this would help.
1 month ago Feb 19, 2026
Hi @haanaa ,
You are not missing anything. This is expected behaviour for Android.
When a Wi-Fi policy is deployed, the configured network becomes available on the device. However, Android does not force a network switch if the device is already connected to another Wi-Fi network.
For devices enrolled with Device Admin privilegesthe user must manually connect to the configured SSID once from the device. On Android 10 and later, you may also see a one-time prompt to Allow suggested Wi-Fi networks. After this initial interaction, the device can automatically connect to the configured Wi-Fi network going forward, as long as the configuration remains available on the device.
Isabel Lora
1 month ago Feb 20, 2026
What if the Wi-Fi configuration that was pushed earlier is later removed from the device? Will the device immediately disconnect from that Wi-Fi network?
No, the device will not disconnect immediately.
When a Wi-Fi configuration is removed from the device, the device continues to stay connected to that Wi-Fi network until it can connect to another available mobile or Wi-Fi network.
