Need to deploy a .dmg fileSolved
2 months ago Feb 11, 2026
Hi team,
I have a macOS application in .dmg file format. How can I deploy and install this on my mac device?
Hi, you can deploy a .dmg file by uploading it as an Enterprise app in the Hexnode UEM portal. Please follow these steps below:
  1. Navigate to Apps > Local Apps > +Add Apps.
  2. Select Enterprise Apps.
  3. Choose the macOS platform.
  4. Select DMG file as the application type.
  5. Upload the .dmg file and configure the required details.
  6. Click Add.
Once the app is uploaded successfully, you can proceed with installation using the Install Application action or the Required Apps feature.
Clara sterling,
Hexnode UEM.
