Need the post-install scripts for LinuxSolved
6 hours ago Apr 03, 2026
Is there a way to specify a post-install script for Linux app installations?
4 hours ago Apr 03, 2026
@eliizaat the moment, there isn’t a way to attach or trigger a post-install script directly as part of an app installation workflow on Linux devices.
If your goal is to run additional commands after an app is installed, you can use the Execute Custom Script remote action. This allows you to run scripts on the device after the installation is complete, but it needs to be triggered separately.
If you’re looking for a fully automated flow where the script runs immediately after the app installs, that isn’t supported right now. I’ve shared this as a feature request with the product team so it can be considered for future updates.
3 hours ago Apr 03, 2026
Alright, thanks!
