Need application report with username. How do I export?Solved
2 months ago Feb 12, 2026
Hi everyone,
I’m trying to export an application report as a CSV from Hexnode. I need the username alongside the application name in the exported file.
How can I do this? Please let me know. Thanks!
Hi @_janet
To ensure we’re on the same page, could you please confirm which username you are referring to?
Are you looking for the user assigned to the device on which the application is installed?
Yes, that’s correct. I’m looking for the user assigned to the device.
Thanks for confirming, @_janet .
To include usernames in your application report, navigate to:
Reports > Built-in Reports > Applications > All Applications.
When exporting the report as a CSV, select the required apps and make sure to select the “User List” option. This will include the actual usernames mapped to each application in the exported file, instead of showing only a numeric count.
You’ll then be able to see exactly which users are associated with each application in your CSV.
