Move devices from the default user to a named user in HexnodeSolved
2 months ago Aug 19, 2026
I have several devices currently assigned to the default user in Hexnode and want to move them to named users. I created the first user and need to reassign that user’s device.
What is the correct option for this? I noticed ownership-related actions in the portal, but I’m not sure if changing the owner will show anything on the device or notify the end user.
Hello @ezekiel ,
You can reassign a device from the default user to a named user by using the Change owner action in the Hexnode UEM portal.
Steps:
  1. Go to Manage.
  2. Select the required device.
  3. Click Actions.
  4. Navigate to Edit > Change owner.
  5. Select the domain.
  6. Choose the user you want to assign as the device owner.
  7. Click Assign.
This updates the device-owner mapping in Hexnode UEM. It does not trigger a pop-up, notification, or visible interruption on the device.
