Keep getting itunes login prompt for Apple books & home in kioskSolved
7 months ago Feb 27, 2026
Hi everyone,
I’m running into an issue with ipads in multi app kiosk mode. I need to keep “Apple books” and “Apple home” available to our users. I added them as required apps in my policy, but the devices are prompting for an iTunes login to install them. Since these ipads aren’t shared devices and don’t have individual iCloud accounts associated with them, they get stuck and the apps won’t install.
I can’t find these apps in Apple Vpp to buy licenses for a silent install, and they aren’t considered system apps when I search for them in Hexnode during policy creation. I also have an App Allowlist that mirrors my required apps.
Am I missing a step on how to push these apps to a kiosk without requiring an Apple ID? I’m relatively new to MDM, so any help is appreciated. Thank you!
7 months ago Feb 28, 2026
Hi @tomas, welcome to the Hexnode community! Don’t worry, you aren’t misinterpreting anything. This is a very common hurdle when dealing with Apple native apps.
Here is what is happening behind the scenes. Apple Books and Apple Home are preinstalled system apps, but Apple treats them as App Store apps for updates and redownloads. Because they cannot be purchased and deployed silently via VPP, pushing them through a Required Apps policy forces the iPad to ping the App Store, which triggers the Apple Account prompt.
To get your Kiosk running smoothly without the login prompts, you will need to adjust the deployment order. Here is the best workaround:
  1. Install the apps before applying the Kiosk policy  Because of Apple restrictions, these specific apps must be physically present on the device before the Kiosk lockdown is applied. You will need to ensure they are downloaded first. You can install them using the Install Application remote action or a Required Apps policy.
  2. Remove them from Required Apps  To stop the recurring iTunes login prompt, remove Apple Books and Apple Home from your Required Apps list. Keeping them there is what causes the policy to constantly attempt a fresh App Store installation.
  3. Add them to your Kiosk Once the apps are on the device, you can add them to your Kiosk configuration. Go to Kiosk Lockdown > iOS Kiosk Lockdown > Single App/Multi App, click + Add App, and use their specific Bundle IDs:
    • Apple Books: com.apple.iBooks
    • Apple Home: com.apple.Home
  4. Update your Allowlist  Since you mentioned using an Allowlist, make sure those exact Bundle IDs are also added there so the Kiosk does not accidentally block them from opening.
To keep things simple moving forward, ensure the apps are installed first, and then push your Kiosk policy.
Let us know if this gets those iPads up and running!
Cheers,
Eden Pierce
