Is there a way to check the device count for apps?Solved
2 months ago Feb 06, 2026
Is there a way to find out how many devices have a particular application installed, and export that data?
Replies (6)
1 month ago Feb 06, 2026
Hey @mees
Yes, there is a way to find out how many devices have a particular app installed.
Sign in to Hexnode UEM, then navigate to Reports > Built‑in Reports > Application > All Applications. After locating the application, you can view the number of devices that have it installed.
To export and download the data, select the application and click Export. Once the export is complete, go to the Exports section under the Reports tab to download the exported file.
Henxode UEM
Got it! Thanks, @simon_scott .
Is it possible to get a list of the devices that have a particular application installed?
Yes, you can.
In the All Applications report, select the required application and click the device count displayed in the corresponding column. This will open a detailed view of the devices on which the application is installed.
To export the data, click Export. In the export dialog, choose Device list from the Export dropdown. You can either select specific columns manually (such as device name, username, OS name, OS version, serial number) or include all columns. The downloaded export file will then provide the details of all devices where the application is installed.
So only application reports are possible? Or can we get reports for any other fields too?
Hexnode UEM offers a wide range of reports covering applications, devices, users, compliance, and more. For detailed guidance, check out our guide on the Reports tab.
