Is there a way to check app installation status for a device group?Solved
1 month ago Mar 12, 2026
Hi everyone,
We’re handling quite a few devices, and keeping track of app installation status has started to feel a bit tedious. At the momentwe’re opening up individual devices just to check if an app went through properly, which obviously doesn’t scale well.
Just wondering—are we missing something here 🤔? Is there an easier way to get a quick view of installation status for a whole group?
Hi @it_christo !
You don’t actually need to go device-by-device for this. You can use the Reports section in Hexnode UEM to get a consolidated view. Go to: Reports > Applications > All Applications.
From there, you’ll see a list of apps along with the number of devices they’re installed on. If you click on the device count next to a specific app, it will show you the list of associated devices.
If you have further questions, feel free to contact us.
Hexnode UEM
1 month ago Mar 13, 2026
We started using this recently, and one thing that helped us was using it as a quick validation step after pushing apps. Instead of waiting for users to report issues, we just check that view to spot if any devices didn’t pick up the install properly. If something looks off, we can act on it right away.
Made our rollout process a lot smoother compared to before.
