Is mobileconfig file deployment available in my current Hexnode subscription tier?Solved
1 month ago Feb 25, 2026
Hi team, I’d like to know if mobileconfig files can be deployed using Deploy Custom Configuration policy on macOS devices under our current Hexnode UEM subscription tier.
Hello @diane_ ,
Could you please confirm which subscription plan you’re currently on? That will help me check the availability of this feature.
We’re on the “Ultimate” plan.
Thanks for confirming. Custom configuration deployment using mobileconfig files isn’t available for the Ultimate plan. This feature is supported only in the Ultra plan.
Understood, that clears it up.
Thanks @simon_scott .
Glad I could help. If you’d like more details on upgrading to the Ultra plan or exploring other configuration options available in your current tier, feel free to reach out to our support team.
