Introducing Automation TemplatesSolved
2 months ago Feb 05, 2026
Introducing the Templates subtab under the Automate tab—your new hub for one-click, expert-level automation. We’re kicking things off with the highly requested workflow: Upgrade to Windows 11.
We know that transitioning an entire organization to a new Windows OS version can feel like a high-wire act, but we’re here to give you a safety net.
Upgrade to Windows 11 without the complexity
OS updates are often slowed down by custom scripting, inconsistent execution, and user delays. Now you can forget the days of wrestling with complex scripts and crossing your fingers during deployment. The new Upgrade to Windows 11 automation template eliminates those challenges with a ready-made, reliable workflow designed by Hexnode experts.
This system-defined template lets you create and schedule Windows 11 upgrade automations in just a few clicks—no scripting, no guesswork.
What’s New?
  • The Templates Library: A brand-new subtab within the Automate section. Think of it as your “Automation Store,” featuring pre-built, system-protected templates created by Hexnode experts.
  • The “Upgrade to Windows 11” Master Template: An immutable, rock-solid blueprint for OS upgrades. Use it as a base to create custom automations in seconds.
  • Smart Restart Enforcement: No more “Remind me tomorrow” loops. The template includes logic that notifies users of the update but prevents them from postponing the final, critical restart.
  • Zero-Distraction Deployment: The download and installation phases run silently in the background, suppressing status notifications until the finish line.
