iMessages on new devicesSolved
5 months ago Nov 01, 2025
Hey fellas! Just upgraded my iPhone, and my iMessages are acting a bit weird. The new device is enrolled in Hexnode, and the messages aren’t transferring like they used to. Anyone else run into this or know a fix?
5 months ago Nov 02, 2025
You could try restarting your phone. If that doesn’t help, maybe a hard reboot could do the trick. Also, you might want to check your Wi-Fi or mobile data connection since iMessages need that to sync properly.
5 months ago Nov 03, 2025
This happened to me too! You could try signing out and back into your Apple ID, that’s what finally fixed it for me.
Check out this doc: https://support.apple.com/en-in/119859
Since your device’s managed through Hexnode, you could also check if there’s a restriction on iMessage. Sometimes that can block the sync.
5 months ago Nov 06, 2025
Have you found a fix yet? I’m going through this right now and it’s driving me crazy.
5 months ago Nov 07, 2025
It actually resolved itself over time. One more thing you could check is under Settings > Phone, make sure your correct number appears in the “My Number” field. If it’s blank, iMessage won’t sync properly.
