How to deploy Sophos using Hexnode?Solved
6 months ago Oct 01, 2025
Hey everyone! Struggling a bit with deploying Sophos via Hexnode. I have been at it for a while now, and I could really use some help.
Hi @skyler! Thanks for reaching out.
Could you let us know which platform you’re deploying on? Also, have you already started the setup, or are you unsure where to begin?
6 months ago Oct 04, 2025
Oh right, should’ve mentioned, it’s on macOS Sequoia. I’ve gone through a few steps, but I’m not sure I’m following the right deployment flow. Feels like I’m missing something.
No worries @skyler, we’ve got you! Let me walk you through the steps of deploying Sophos via Hexnode.
Before proceeding, ensure your macOS device is enrolled in Hexnode UEM and that you have a valid Sophos Central account with the required subscription. Additionally, verify that your macOS version is supported by referring to the Sophos Supported OS Builds documentation.
Deployment Steps:
  1. On your Hexnode UEM console, navigate to Policies > New Policy > macOS.
  2. From the left-hand menu, select Scripts and click Configure.
  3. Click on Choose Scripts and choose the Sophos installation script (provided below). Within the script, replace the placeholder URL with the actual download link obtained from the Sophos Central portal. This link should point to the location of the Sophos installation package.
    • To retrieve the correct URL, log in to Sophos Central, go to Devices > Installer > Endpoint, and download either the full macOS installer or the specific components required for your deployment.
    Following is the installation script:
  4. Once the script has been added, a configuration window will appear, allowing you to adjust the installation settings according to your deployment requirements.
  5. Next, navigate to the Deploy Custom Configuration policy. Click Configure and select the appropriate configuration file to be deployed.
  6. Following is the configuration profile for macOS Sequoia:
  7. Click on Save and associate the policy with the target device.
Once the policy is applied, Sophos system extensions are added to the device’s login items, and various Sophos applications are installed. After successful deployment, the device will appear in the Sophos Central portal under Devices > Computers and Servers.
Disclaimer:
  • The information provided here is vendor-specific and may be subject to change. Please refer to the official Sophos website for more information or technical support.
  • Hexnode is not responsible for any issues resulting from the installation or use of third-party software.
  • It is strongly recommended to test the deployment script and configuration profile on a limited number of devices before proceeding with bulk deployment to avoid potential issues.
6 months ago Oct 10, 2025
Thanks for the detailed walkthrough! I’ll go ahead and proceed with the setup now.
You’re welcome! Feel free to reach out if you have any questions along the way.
