How does Autopilot actually work during setup?Solved
11 hours ago Apr 03, 2026
Hey people, we’re planning to use Windows Autopilot, but I’m not fully clear on what happens when the user first turns on the device. Does it install anything or is it just enrollment?
8 hours ago Apr 03, 2026
@jennifer, it’s a fair question. Autopilot gets misunderstood a lot here. It doesn’t reinstall Windows or set up the device from scratch. The OS is already there. What Autopilot does is recognize the device and pull it into your organization’s setup.
6 hours ago Apr 03, 2026
Got it. But how does it recognize the device?
4 hours ago Apr 03, 2026
That’s handled using the device’s hardware hash, which is uploaded beforehand (usually by your vendor). When the device is powered on and connected to Wi-Fi, it contacts Microsoft, identifies itself, and gets told which organization it belongs to. From there, it’s redirected to your Hexnode environment.
Enrollment then kicks in via Entra ID, and once that’s done, Hexnode starts pushing your apps, configurations, and policies to the device.
3 hours ago Apr 03, 2026
So basically, nothing is being “installed” beforehand?
2 hours ago Apr 03, 2026
Exactly. No imaging, no USB, no PXE. Just identity + configuration applied at setup.
Everything happens during setup based on the device identity and what you’ve already configured.
