Facing Error code -36 on my Mac while copying files?Solved
11 months ago May 01, 2025
I was trying to copy a bunch of files from an external drive to my Mac, and suddenly I got this “Error code -36” pop-up. It failed midway, and now every time I try again, it stops at the same file.
The weird thing is, I noticed the filename has a dot at the beginning and maybe an underscore too.
Is this some kind of hidden file issue?
11 months ago May 02, 2025
Yep, that sounds like it. Error code -36 usually pops up when finder can’t handle certain hidden files—especially ones with a “.” at the beginning and an “_” in the name. These files can get corrupted, and when that happens, Finder struggles to move, copy, or delete them properly.
11 months ago May 03, 2025
That makes sense. So how do I fix it? Do I just delete those files or…?
11 months ago May 06, 2025
No need to delete anything. Here’s a quick fix using terminal:
  • Open terminal from Applications > Utilities.
  • Type dot_clean (with a space at the end).
  • Then drag the folder containing the files into Terminal—it’ll fill in the path automatically.
  • Press return.
That command basically merges hidden metadata files with the main ones, which usually clears up the issue. After that, try copying or moving the files again.
11 months ago May 08, 2025
Also, just to add—sometimes it’s a permission thing. You can right-click the file, hit Get info, scroll to Sharing & permissions, and make sure your user has Read & write access. You might need to unlock it with your admin password to change the settings.
11 months ago May 10, 2025
Ahh I see. I’ll try the terminal method first-it sounds simple enough.
If that doesn’t work, I’ll double-check the permissions. Thanks for the help, both of you!
