Can I set up alerts for when a device becomes active or comes online?Solved
3 weeks ago Mar 17, 2026
Hey, I was looking for a way to get a notification the second a device comes online or shows as ‘Active’ in the portal so I can assign final tasks
Hexnode provides a number of alerts right? I guess it should be there in it.
Thanks for raising this question!
At the momentHexnode does not provide direct alerts for when a device specifically switches to ‘Active‘ or comes online. However, we do offer a variety of other Alert Profiles to help you stay on top of your fleet. If your goal is to track device status, the best approach is using Compliance Policies.
Once you have set your criteria (such as required appspassword rules, or encryption), Hexnode will trigger an alert the moment a device meets all those factors and its status changes to Compliant. This is often the most effective way to know a device is fully functional and ready for use.
