Can I see how much time users spend on a specific app?Solved
2 months ago Feb 03, 2026
We just deployed a new CRM app to our sales team tablets, which are Android. My boss wants to know if they are actually using it, or if they are just opening it once and closing it.
I know I can see how much data an app uses, but is there a report that shows the actual duration or “screen time” spent inside a specific app? I need to prove ROI on this deployment.
Hi @margaret ,
Thank you for reaching out. Hexnode supports App Usage Management for Android devices, which gives you exactly the metrics you are looking for. It goes beyond just data usage and lets you track:
  • Total time spent on the app (Duration).
  • Launch count (How many times it was opened).
  • Last used timestamp.
  • How many notifications are received from each app.
You can view this data for individual devices or pull a summary report for the whole fleet to see adoption rates. Here is the guide on tracking app usage on Android devices.
Got a question or a tip to share? Start a discussion below or reach out to our team directly at support@hexnode.com.
Cheers,
John Cooper
