Can I provision unique identity certificates to iOS devices without manual effort?Solved
6 months ago Apr 30, 2026
We need to get unique identity certificates onto our iPhones for VPN access. I don’t want every device using the same one, and I definitely don’t want to manually create and upload hundreds of individual files. Is there a better way and how it benefits us?
You should look into SCEP. It’ll be a solution for this because instead of you uploading a file, the devices request their own unique certificates directly from your CA in the background.
It sounds good, but what about the security concerns, what if a generic certificate got deployed to all the devices.
Hello everyone,
Managing large-scale certificate deployments manually often leads to administrative bottlenecks and potential security risks. Implementing an automated workflow via SCEP is the most effective way to address these challenges while maintaining a secure environment.
Here is how this approach benefits your deployment:
  • Bulk Scalability: By utilizing SCEP with Hexnode UEM, you can deploy certificates to thousands of devices simultaneously. The system automates the communication between the iPhones and your Certificate Authority, removing the need for manual installation on individual devices.
  • Unique Identities: To address security concerns, this process ensures that every device receives a unique certificate. The private key is generated locally on the iPhone and cannot be exported, ensuring that the identity remains tied strictly to the authorized device.
This automation streamlines the onboarding process and ensures that your network remains protected without requiring constant manual oversight.
To understand the strategic advantages of implementing automated certificate workflows, please refer to our guide on Bulk iOS SCEP Certificate Automation.
