Hi @wyatt_simmons ,
Hexnode UEM currently does not support direct export of report graphs or dashboard charts as downloadable visual files.
The export options available from the Hexnode UEM console are intended for tabular report data, typically in PDF or CSV format. While charts such as pie charts and bar graphs may be visible inside the dashboard or report interface, those visual layouts cannot be exported directly as graph images or chart-based reports.
As a workaround, export the report data as a CSV file and use an external tool to create the required visuals. For example:
- Export the required report from Hexnode UEM as a CSV file.
- Open the CSV in Microsoft Excel, Power BI, or another reporting/BI tool.
- Create the required charts or graphs from the exported data.
- Export or share the final visual report from that tool.
This is the recommended approach if you need graph-based reporting for presentations, stakeholder updates, or custom dashboards.
