Automation levels up: More actions, less hassle! Solved
6 months ago Sep 19, 2025
It’s upgrade time again at Hexnode UEM!
After bringing remote actions into Automation, we’re back with another big boost: an expanded lineup of actions across platforms. These actions were already available as direct actions in Hexnode, but now you can also schedule and automate them for a smoother, hands-off device management experience.
Here’s what’s new in this phase of the rollout:
Android
  • Device Control: Set Friendly Name, Change Owner, Import Contacts, Change Ownership, Update OS, Clear App Data
  • Scans: Scan for Apps
  • Security: Remote Ring
  • Kiosk: Enable Kiosk Mode, Disable Kiosk Mode
  • App Management: Install Application, Uninstall Application
iOS
  • Device Control: Rename Device, Set Friendly Name, Change Owner, Change Ownership, Clear Activation Lock, Update OS
  • Security: Wipe Device, Remote Ring
  • Network: Enable Data Roaming, Disable Data Roaming
Windows
  • Patches and Updates: Auto Patch, Manual Patch
  • App Distribution: App Distribution
  • Device Encryption: Unlock BitLocker
  • Groups and Domains: Join AD Domain, Unjoin AD Domain
macOS
  • Device Control: Set Friendly Name, Change Owner, Change Ownership, Clear Activation Lock, Update OS
Apple tvOS
  • Device Control: Set Friendly Name, Change Owner, Change Ownership, Update OS
Linux
  • Device Control: Power Off, Restart Device, Set Friendly Name, Change Owner, Change Ownership, Update OS
  • Scans: Scan Device, Sync Local Accounts, Scan for Apps
  • User Controls: Create User Account
  • Security: Lock Device, Wipe Device
  • Scripts: Execute Custom Script
With these additions, Automation becomes more powerful than ever, letting you move beyond one-off actions to fully planned and streamlined workflows.
For a full breakdown and step-by-step guidance, check out our help documentation. And as always, your feedback on Hexnode Connect is invaluable.
Eden Pierce
