Authenticator app crashes with ‘Access Denied’ when opening screen lock in kiosk modeSolved
4 months ago Dec 04, 2025
Hey everyone, I’m running into an issue on one of our Android devices in kiosk mode.
We’re testing an authenticator app with passkeys/passwordless login. The app requires setting a screen lock to complete the login, but when the screen lock settings are opened, it shows “access denied” and the app crashes immediately.
Has anyone run into this before?
Hmm… that sounds familiar.
Just to be sure, is there any password or security policy still applied to the device or its groups?
4 months ago Dec 05, 2025
Yep, checked that already. No password policies are applied anywhere. The device only has a kiosk policy active.
Hey @diane_!
A possible cause could be that a system package that Android needs for the screen-lock setup is blocked in kiosk mode.
If Android can’t access that system component, the app will show “access denied” and crash when trying to open the screen-lock settings.
Here’s how to fix it:
  1. Login to your Hexnode UEM portal and run a Scan device action on the affected device.
  2. Navigate to Manage > select the device > Applications.
  3. Check the Blocked Packages list for any system package related to screen lock, authentication or settings that might be restricted.
  4. Then go to Policies > select your kiosk policy > Modify > Background Apps and add the missing package so Android can open those settings in the background.
If the package does not appear in the Background Apps selection list:
Once that system package is allowed, please check if the authenticator is able to open the screen-lock setup without crashing.
If you want further assistance, feel free to contact us.
