App Bundle Configuration IssueSolved
1 month ago Feb 26, 2026
Hi everyone, I’m running into a bit of a snag with App Bundles. I’ve successfully added an app to my app inventory, but when I go to create an App Bundle, can’t select it as the principal app. It simpldoesn‘t show up on the list. Is there a specific steI’m missing to make it visible?
Replies (6)
Hello @mike_johnson . To clarify, is the app you are trying to select a macOS enterprise app?
It’s a Windows app. I don’t currently have any macOS enterprise apps uploaded to my inventory. Does the operating system affect the principal app selection?
Yes, @mike_johnson that explains the behavior you are seeing. In Hexnode UEM, App Bundles currently support macOS only. Consequently, Windows apps cannot be selected as the Principal App when creating a bundle.
@elle_reed , so, if we don’t have any macOS enterprise apps uploaded, will the principal app selection list remain empty?
That is correct, @leo_scott Because the feature is exclusive to macOS, the principal app list will remain empty if you do not have any macOS enterprise apps in your inventory.
Understood. Thanks @elle_reed .
