API – macOS Update payloadSolved
3 months ago Dec 08, 2025
End-state: I want to use the API to create a macOS update policy with the download only requirement and the preferences and deferal.
But…I made a macOS update policy that included the scheduling so that I can see what the payload looks like to be able to create it through the API but I’m only getting the below back with the install action.
Is the API response suppsoed to give back the other details, e.g. Software Update Preferences and Defer Software Updates. If it’s not coming back through the GET request I presume we can’t use it for a policy creation POST request payload?
3 months ago Dec 10, 2025
Hello,
Thank you for reaching out to Hexnode Connect.
We understand your requirement to enable APIs to create a macOS update policy along with a set of preferences. We have conveyed your request to the necessary teams, and they will look into this. We will get back to you with any updates as soon as possible.
Thank you for your patience. In the meantime, please feel free to share your insights on any matter or any queries you might have regarding Hexnode UEM, and we will try to resolve them.
George
3 months ago Dec 11, 2025
@George Thanks. No other questions. Really from the macOS and Windows side just hoping to get more verbose output from the API and ability to configure additional policy settings via the API so that it’s not all required via the UI
