Anyone figured out how to skip the cert picker in Chrome kiosk?Solved
2 months ago Feb 11, 2026
Hey folks,
I’m pushing a client certificate to a few Android Enterprise device owner devices. The cert is needed to access a website, and I’m running that site using Google Chrome as a web app in single-app kiosk mode. The issue is that every time the site loads, Android pops up a certificate picker. That kind of defeats the whole kiosk idea.
Anyone know if there’s a way to have the cert picked automatically so the user never sees that prompt?
Hi @vance_j .
I remember coming across a Chrome configuration that might help here. There’s a policy where you can associate specific URLs with a client certificate so Chrome auto-selects it instead of showing the picker.
Might be worth checking if that works for your setup.
