Where to find the Geofencing section in Hexnode?Solved
6 months ago Jun 01, 2026
Hi, I’m trying to set up geofencing in Hexnode but can’t find where the geofence section is in the portal. Where do I go to create a new geofence or location fence?
Hi @schyler-scott,
You can create a geofence from the Hexnode portal by going to Admin > Geofencing and selecting Create Fence. From there, search for the required area using the Enter a location field. Once the location appears on the map, you can define the fence region as needed.
Found it, I was looking for it inside the policy section, so that was the confusion. Thanks!
