Struggling with script sprawl for mixed hardware fleets; any better way to manage this?Solved
9 months ago Feb 21, 2026
Hey everyone. I manage an enterprise fleet that is a massive mix of Dell, HP, and Lenovo machines. Lately, my script repository has turned into a total mess. I have separate configuration policies for each vendor because we need to push specific driver optimizations and registry keys depending on the hardware. On top of that, I keep running into issues where scripts need the logged in user details to configure their local profile, but hardcoding is not an option. Is there a cleaner way to handle this in Hexnode without maintaining a dozen different script variations?
Look into the Dynamic Scripting Framework in Hexnode. It basically turns your endpoint management into a programmable infrastructure. Instead of having separate policies, you can use Dynamic Branching Logic within a single Smart Baseline script. For example, using a simple PowerShell script with a switch statement, you can query the hardware manufacturer on the fly and apply the right registry keys dynamically. Also, for your user profile issue, you do not need to hardcode anything. Hexnode supports wildcards like %username% or %deviceid% that inject real time data right when the script executes. Just make sure you select the User context instead of System context in the execution scope so it applies to the user profile properly.
9 months ago Feb 22, 2026
Since these scripts might get pushed multiple times or triggered on device check-ins, how do you prevent them from messing up existing configurations or creating duplicates? And from a compliance standpoint, how are you tracking if a specific hardware revision fails during execution? We have strict audit requirements.
That is exactly where the concept of Idempotency comes in. You just need to design your scripts so they check the current state before making changes; that way, running them multiple times yields the exact same result without breaking anything. As for the compliance and failure tracking, the framework gives you full auditability. A pro tip from my own experience is to always wrap your script logic in Try/Catch error handling blocks and return specific exit codes. Hexnode reporting engine will pick up those exact exit codes, so if a specific Lenovo model fails, your logs will tell you exactly why. It makes passing those compliance audits an absolute breeze!
