Windows device locked out: can Hexnode create a local user or block USB reinstall?Solved
3 months ago Sep 07, 2026
We have a few Windows devices enrolled in Hexnode, but no one can sign in because the available user passwords are unknown. We tried booting from a Windows USB installer to wipe/reinstall the OS, but the keyboard and mouse stop responding at the Windows setup screen. Can Hexnode create a new local admin account if the device is sitting at the Windows sign-in screen? Also, can Hexnode prevent someone from force-reinstalling Windows using USB boot on a managed device?
A Windows device can receive Hexnode commands from the sign-in screen if it is powered on, connected to the internet, and actively checking in with Hexnode. A user does not need to be signed in for every command to execute.
If the device is online and communicating, you can create a local user from the Hexnode portal:
1. Go to Manage > Devices.
2. Select the Windows device.
3. Click Actions > Policies and Accounts > Create Local User.
4. Enter the required user details and send the command.
The device will not show a prompt for this action. If the command executes successfully, the local account is created in the background and you can use those credentials at the Windows sign-in screen.
However, if the device is offline, in sleep/hibernation, in BIOS/UEFI, in recovery, or booted from external media, it will not receive the command. In that case, the action remains pending until the device checks in again.
So just to confirm, a Windows device can still be considered online even if nobody is logged in? I always thought the MDM agent would only work after a user signs in.
Yes. A Windows device can continue communicating with Hexnode from the sign-in screen as long as the OS is running, the Hexnode agent/service can operate, and the device has network connectivity.
The important distinction is: – Windows sign-in screen: commands may still be received if the device is online. – BIOS/UEFI, boot menu, Windows installer from USB, or recovery environment: Hexnode cannot communicate with the device because the managed Windows OS and Hexnode agent are not running. If the device’s last check-in is very old, the portal may still list the device, but newly pushed actions such as Create Local User will not execute until the device comes back online and checks in.
