Hello @rob_mitch ,
The indefinite timer happens when a remotely locked Mac stays offline long enough for its battery to drain completely. When the Mac powers back on, its system clock resets to Epoch time (January 1, 1970). Since the device is locked, it cannot connect to Wi-Fi to sync its clock, so macOS calculates the lockout timer against incorrect system time making it appear locked indefinitely. Also, startup options being blocked is expected while the Mac is in the remote lock state.
If you have the System PIN used for the remote lock, you can clear the timer by syncing the Mac’s clock over a wired network:
Connect the Mac to an active network using a USB-C to Ethernet adapter.
Keep the Mac powered on and connected for 10–15 minutes so it can reach Apple’s time servers.
Restart the Mac.
Once the system date and time sync, the false lockout timer will clear and allow you to enter the System PIN.
If the PIN is unavailable, or if the timer does not clear after an Ethernet time sync, connect the Mac to another Mac running Apple Configurator and perform a Revive (which updates firmware without erasing user data). If Revive fails, a Restore will be required but note that Restore will completely erase the device and reinstall macOS.
