macOS device rename not applying properlySolved
7 months ago Apr 13, 2026
Hey guys,
I’m trying to rename a few macOS devices using user details, but on some devices the rename just doesn’t go through. No proper error, it just doesn’t stick. Not sure what I’m missing here—any ideas?
Hmm, I think I’ve heard of something like this before. What’s the username on one of the affected devices?
One of them is “Robert Williams”.
Ahh okay, yeah… that’s exactly what I was guessing 😄. The issue is the space. macOS (especially the LocalHostName part) doesn’t really handle spaces well. So, when the rename tries to apply that value directly, it just fails silently in some cases.
I had a small script saved for this kind of scenario—basically you pass the values and set the name explicitly instead of relying on the default rename behaviour:
‍You can pass stuff like %name% and %devicenotes% into it.
Ohhh got it, that makes sense now. But how would I run this on the device? It’s with a field employee, so I don’t have direct access.
Yeah that’s pretty common.
You don’t need physical access for this. Just use the execute script action from your console. Upload the script there, pass the required values as arguments, and push it to the device.
We’ve done this for remote users as well, works without any issues 👍
