Is there a way to send enrollment invitations to multiple iPad users at once?Solved
10 months ago Feb 10, 2026
We need to enroll around 300 iPads for users across different departments. Sending enrollment emails individually is taking too much time. Is there any way to handle this in bulk through Hexnode?
Hi @harold,
Yes. Hexnode supports bulk enrollment using CSV import. Instead of creating and sending enrollment requests one by one, you can upload a CSV file containing the required user and device details, and Hexnode will automatically generate and send enrollment invitations to multiple users simultaneously.
10 months ago Feb 11, 2026
What kind of details can be included in the CSV file, and how can it be used in organizations with multiple departments?
9 months ago Feb 11, 2026
Hi @harold,
The CSV file can include details such as the user name, email address, phone number, ownership type, and device-related information depending on the enrollment workflow being used.
Many organizations prepare the CSV department-wise, so devices and users can be categorized properly before enrollment begins. This becomes especially useful when different teams require different configurations, restrictions, or applications after enrollment.
9 months ago Feb 12, 2026
Can apps be installed automatically after enrollment?
Hi @jimena,
Yes. If the iPads are enrolled as supervised devices, applications can be silently deployed from Hexnode without requiring user interaction. For more information, do check out this documentation on silently deploying apps on iOS devices.
