iPad asks for passcode after factory reset and Clear Passcode does not workSolved
8 months ago Mar 26, 2026
One of our managed ipads suddenly started asking for a passcode at the lock screen. It was not doing this earlier. The device also looks like it may have been factory reset because the setup language keeps changing, but the old wallpaper is still visible. I tried using the clear passcode action from HExnode, but the iPad is still asking for the passcode. Since it looks reset, it is not connecting to Wi-Fi, so I cannot push anything to it either. Does Hexnode store the current ipad passcode anywhere, or is there another way to unlock it from the portal?
We ran into this before when a device was stuck before network setup. If it is already wiped, MDM commands will not reach it. Also check if it is the local device passcode screen and not an Activation Lock prompt, since that is handled through the apple iOS process instead.
8 months ago Mar 27, 2026
Hi @carter and @bram,
Sara is absolutely correct regarding device connectivity and the prompt type. Hexnode does not store, display, or retrieve device passcodes, and they cannot be viewed by administrators in the portal.
The Clear Passcode remote action will only work when the device is still managed by Hexnode and actively connected to a network to receive the command. Because the device appears to have been factory reset and is offline, Hexnode cannot push commands, Wi-Fi settings, policies, or passcode actions to it.
If the device is at the local iOS lock screen and cannot communicate with the server, it cannot be unlocked from the Hexnode UEM portal. The device will need to be recovered using Apple’s available recovery or reset options, and then re-enrolled into Hexnode if required. Additionally, as @bram mentioned, if the prompt is an Activation Lock screen instead of a standard device passcode screen, that is handled strictly through Apple’s Activation Lock process.
Please let us know if you need any documentation on the re-enrollment process once the device is recovered.
Eden Pierce,
8 months ago Mar 28, 2026
that explains why the clear passcode action did nothing, thank you for the help.
