iOS VPP app grayed out and stuck installing after managed deploymentSolved
2 hours ago Nov 30, 2026
An iPhone was just set up and Outlook was deployed as a managed app through Hexnode. The app icon is grayed out on the home screen like it is waiting to install, but it never opens.
In the app catalog, the app shows that it requires an update, but choosing Get only shows an action initiated message and nothing changes. In Hexnode, the app is shown as installed, but there is no manage option available for it. The user also cannot uninstall it from the device.
Things already tried:
  • Tapping the grayed-out app icon to resume the install
  • Restarting the iPhone
  • Running Install Application from the device Actions tab
  • Syncing Apple VPP and trying the install again
The install action keeps failing, and the error says the app is already scheduled for management. Is there any way to remove and reinstall the app without wiping the device?
10 minutes ago Nov 30, 2026
A grayed-out app icon on iOS usually indicates that the app is stuck in a pending, installing, paused, or update state. For managed VPP apps, Hexnode sends the install or management command to Apple, and the final installation is processed by Apple’s service on the device.
For this scenario, the correct checks are:
  1. Tap the grayed-out app icon on the device to see if the download resumes.
  2. Restart the iPhone and check whether the install continues.
  3. From Hexnode, try the Install Application action again for the affected app.
  4. If available, try the Uninstall Application action from the device Actions tab.
  5. Sync Apple VPP from the Hexnode UEM portal and retry the installation.
If the action history shows the install failed with a message similar to “app is already scheduled for management,” it usually means the app management command has already been handed off and queued for processing. In that state, Hexnode cannot manually force the installation beyond Apple’s processing queue.
