Hexnode Store: what is it?Solved
6 months ago Sep 21, 2025
Hey there,
what is this Hexnode store? Usually when I open the Apps tab, it shows the App repository with all types of apps, but now it automatically opens to Hexnode Store. What exactly is it?
6 months ago Sep 24, 2025
Oh boy, where do I start. I felt the same at first and was totally confused. Later I got in touch with a support executive and he explained it pretty clearly.
It is basically their own version of something like the Google play store or the Apple App store, but curated and uploaded by hexnode.
After he explained it, it actually made a lot of sense. Instead of manually adding apps to the Hexnode app repository, whether it is an enterprise app or a store app, if the app is already in the Hexnode store you can directly deploy it using the Install application remote action. It saves a bunch of steps. I think it also makes manual patching easier because they can manage updates on their end.
6 months ago Sep 28, 2025
That is an incredible feature. But it looks like only macOS and Windows apps are available right now. It would have been nice if Android apps were included too.
